VinFast Registrations Rise 33% as Limo Green Drives September 2026 Growth
VinFast registrations increased to 2,967 units in September 2026 from 2,238 in August, representing month-on-month growth of 32.6%. The expansion was overwhelmingly driven by Limo Green, which recorded 2,150 registrations and accounted for 72.5% of VinFast’s total volume. VF7 and VF MPV7 also improved sequentially, while VF6 was the only model to register a monthly decline.
VinFast registrations rose to 2,967 units in September 2026 from 2,238 in August, an increase of 729 units or 32.6%. The headline expansion was strong, but it was concentrated: Limo Green alone added 698 registrations and accounted for 95.7% of the portfolio’s net monthly gain.
Limo Green generated 2,150 registrations and 72.5% of VinFast’s September volume. The rest of the range reached 817 registrations, only 3.9% above August. Within that smaller base, VF7 advanced, VF MPV7 improved from a low level, and VF6 moved in the opposite direction.
The September 2025 comparison is not presented as a growth rate because VinFast recorded only six registrations in the supplied base month. That makes the year-on-year percentage mathematically large but analytically unhelpful; the month-on-month movement gives a clearer view of current momentum.
VinFast model-wise performance
Limo Green dominates the monthly expansion
Limo Green rose 48.1% month-on-month to 2,150 registrations, from 1,452 in August. Its 698-unit increase was more than 22 times the combined 31-unit gain delivered by the rest of VinFast’s line-up. The model therefore shaped both the scale and the direction of the company’s September result.
Limo Green is positioned for fleet use, and Green SM helps explain its scale. Founded by Vingroup chairman Pham Nhat Vuong, the electric taxi and mobility business sits in the wider VinFast ecosystem and uses VinFast EVs in its services and partner fleets. This gives Limo Green a demand channel beyond private buyers. The supplied data does not identify buyers, so it cannot quantify Green SM’s direct contribution.
VF7 grows across four of five variants
VF7 registrations increased 13.8% to 486 units. Four of its five variants grew from August: Wind reached 166 units, Wind Infinity 140, Sky 62 and Sky Infinity 61. Earth was unchanged at 57. The fastest percentage growth came from Sky Infinity, up 45.2%, followed by Wind Infinity at 22.8%.
The 70.8 kWh versions contributed 429 registrations, or 88.3% of VF7 volume. The 59.6 kWh Earth variant supplied the remaining 57 registrations. Wind and Wind Infinity together represented 63.0% of the model’s September total.
VF6 records an 11.2% month-on-month decline
VF6 was the only VinFast model to decline sequentially, falling 11.2% to 278 registrations. The drop came from Wind, which decreased by 67 units to 134. Wind Infinity partly offset that weakness with a 33-unit rise to 109, while Earth slipped by one unit to 35.
Wind remained the largest VF6 variant with 48.2% of registrations. Wind Infinity contributed 39.2% after its strong monthly increase, while Earth accounted for the remaining 12.6%. The gain from Wind Infinity was not enough to offset the 67-unit decline recorded by Wind.
VF MPV7 remains small but positive
VF MPV7 increased 15.2% to 53 registrations from 46 in August. It represented 1.8% of VinFast’s September total, so its contribution to the overall gain was limited. Its seven-unit increase accounted for about 1% of the portfolio’s 729-unit monthly gain
Battery mix mirrors the Limo Green concentration
Across the portfolio, 60.13 kWh models accounted for 2,203 registrations and 74.3% of volume, largely because Limo Green uses that configuration. The 70.8 kWh VF7 variants added 429 registrations, or 14.5%, while 59.6 kWh versions across VF7 and VF6 contributed 335, or 11.3%.
Growth is strong but highly concentrated
September delivered a clear rise in VinFast registrations, but the composition matters. Limo Green was responsible for almost the entire increase, while the remaining models collectively advanced by only 31 units. VF7 provided the broadest positive signal, with growth spread across most variants. VF6 needs a recovery in its core Wind variant for the wider passenger-SUV line-up to contribute more meaningfully.
The next test is whether VinFast can retain Limo Green’s scale while widening growth across VF7, VF6 and VF MPV7. A more balanced contribution would make the portfolio less dependent on one model and turn the September surge into broader, more durable momentum.
Affordable Electric SUVs Coming to India by 2027: 2 Models to Watch
How Much Does It Really Cost to Charge an Electric Scooter at Home?
Ather Konarc S 161 vs Rizta Z 3.5 kWh: Which Top-Spec Ather Makes More Sense?
Can India's Battery Manufacturing Boom Finally Make Electric Cars Cheaper?
VIDA VX2 Battery Plan vs Buying Outright: How to Compare the Real Cost
