Ather Konarc S 161 vs Rizta Z 3.5 kWh: Which Top-Spec Ather Makes More Sense?
Same 3.5 kWh battery, same 161 km claimed range, a ₹12,000 gap on the road. Where the top Konarc and the top Rizta really differ, and who each one suits.
Pick the top variant of either Ather family scooter and you get the same 3.5 kWh battery and the same 161 km claimed IDC range. Yet Ather's Bengaluru price page puts about ₹12,000 between them on the road. So what does the extra money for a Rizta Z actually buy, and what does the cheaper Konarc give you that the Rizta does not?
The answer is less about range than about how each scooter is built. The Konarc S 161 km is the hardware-first option: bigger front wheel, longer-travel suspension, metal body. The Rizta Z 3.5 kWh is the software-first one, with a touchscreen, Google Maps and a longer list of safety features. All figures below come from Ather's own specification and Bengaluru price pages, read on 29 November 2026.
The two are also moving in opposite directions in the showroom. ElecTree's October registration analysis found Konarc registrations more than doubled to 6,577, while the Rizta family slipped 10.7% to 18,926.
Price: the Konarc is about ₹12,000 cheaper on the road
Ather lists the Konarc S 161 km at ₹1,56,998 ex-showroom in Bengaluru and the Rizta Z 161 km at ₹1,66,498, both including the charger. After the ₹5,000 PM E-DRIVE incentive, Ather's current price benefit (₹6,999 on the Konarc, ₹4,499 on the Rizta) and other charges, the on-road figures come to ₹1,53,493 and ₹1,65,670. That is a gap of ₹12,177. The price benefit is a current offer, so the gap can change.
One detail is easy to miss. The Konarc's price includes Ather's combined charger, which adds 450 W to the scooter's 450 W on-board charger. That matters for the charging comparison below.
Range and charging: same battery, different results
Both scooters use a 3.5 kWh pack and both claim 161 km on the IDC cycle. Ather's own TrueRange figure, its estimate for real riding, is where they part: 130 km for the Konarc and 125 km for the Rizta. The Konarc has less torque (16 Nm against 22 Nm) and a lower 70 km/h top speed, against the Rizta's 80 km/h, although its peak power is higher at 4.7 kW against 4.3 kW. Ather does not say what drives the TrueRange gap.
At home, the Konarc S 161 takes 5 hours 40 minutes to reach 80% on its on-board charger, or 3 hours 10 minutes with the included combined charger. The Rizta's spec sheet lists 0–80% times of 6 hours and 3 hours 25 minutes against its 450 W and 900 W home chargers. Check which charger is in your quote. On Ather Grid fast chargers the Rizta Z has the edge: up to 30 km of range in 10 minutes, against 15 km for the Konarc.
Ather's Konarc landing page headlines a 200 km IDC range, but no variant on its specification or price pages carries that figure. The longest listed today is the 161 km version compared here.
Hardware: where the Konarc earns its keep
The Konarc runs a 14-inch front wheel with a 90/90-14 tyre and a 12-inch rear, with 90 mm of telescopic travel up front and 100 mm at the rear monoshock. Ather calls it LongTravel suspension. It also has 16 cm of ground clearance, a metal body and a closed "silent gear drive" in place of the Rizta's belt. On broken roads and speed breakers, the bigger front wheel and extra travel are the most tangible differences between the two.
The Rizta uses 12-inch wheels at both ends and 15 cm of ground clearance. It is the lighter scooter at 125 kg against 129 kg, and its 34-litre boot beats the Konarc's 31 litres. Both use a front disc (220 mm on the Konarc, 200 mm on the Rizta) with a rear drum and combined braking.
Software: the Rizta Z's real advantage
This is where the extra money goes. The Rizta Z has a 7-inch TFT touchscreen running Android with 16 GB of storage, on-dash Google Maps navigation, live location sharing, crash alerts, LockSafe, SkidControl, Magic Twist and an emergency stop signal. The Konarc S 161 also has a 7-inch screen, but it is Ather's simpler DeepView display on a real-time operating system. It covers OTA updates, Find My Scooter, ride stats and theft and tow alerts, without the navigation and the extra safety features.
Warranty is identical: 3 years or 30,000 km for the vehicle and battery as standard, 5 years or 60,000 km on the battery with AtherStack Pro, and an extended battery warranty of up to 10 years or 1,00,000 km as a paid add-on. The Rizta Z comes in nine colours, the Konarc S 161 in four.
Which one should you buy?
If your daily ride involves rough roads, a pillion and the odd pothole you cannot avoid, the Konarc S 161 makes the stronger case. You get the 14-inch front wheel, longer suspension travel, slightly more TrueRange and faster home charging out of the box, for roughly ₹12,000 less on the road.
If you ride mostly in the city, use navigation daily and want the fullest safety software Ather offers on a family scooter, the Rizta Z 3.5 kWh justifies its premium. The larger boot and quicker Grid charging help too.
Whichever you pick, test-ride both back to back on the same route, and ask the dealer to confirm in writing which home charger and which AtherStack plan are included in the quote.
How Much Does It Really Cost to Charge an Electric Scooter at Home?
