Rajasthan and Andhra Pradesh Led October’s Electric Two-Wheeler Gains as Tamil Nadu and Kerala Slipped
Maharashtra still led by volume. The biggest changes came elsewhere, with Rajasthan and Andhra Pradesh gaining ground and three large southern markets falling.
Profile image of author Ashutosh Shukla on ElecTree
Posted on - 30 November, 2026 12:05 PM
TVS iQube, shown for illustration. Rajasthan and Andhra Pradesh posted the biggest October gains in electric two-wheeler registrations.
  • electric two-wheeler registrations
  • October 2026
  • Rajasthan
  • Andhra Pradesh
  • Tamil Nadu
  • Kerala
Rajasthan and Andhra Pradesh added the most electric two-wheeler registrations between September and October 2026 among the larger states, while Kerala and Tamil Nadu each lost close to 4,000. Six of the eleven largest states added registrations, five lost them, and three of the steepest falls came from southern states.
ElecTree’s national October analysis looked at the market through manufacturer-level figures and electric penetration. This piece uses the state-wise series instead, to show where registrations moved. The comparison is month on month only.
The table ranks the 11 largest states by October volume. Together they account for 84% of the October state-wise total. It shows where registrations moved, not who sold the most scooters. A registration records when a vehicle entered the records, which can differ from when the buyer placed the order.
Electric two-wheeler registrations in the 11 largest states, October 2026 vs September 2026, ranked by October volume with unit and percentage change.
Maharashtra still leads, and its share barely moved
Maharashtra registered 30,551 vehicles in October, the most of any state, and held 14.96% of the state-wise total. In September its share was 14.98%. The 705-unit fall was small against its base, so it kept the top spot with almost the same weight it had a month earlier.
Karnataka and Tamil Nadu were second and third again, but both were smaller than in September. Their order did not change, while their shares did. That is the first reason the share view is worth reading alongside the ranks.
Who gained share, and who lost it
Share adjusts for the size of the overall market in each month, so it is a cleaner way to compare a month with the one before. It shows how much a state matters within the state-wise total, not just whether its own count went up or down.
Each state's share of the state-wise electric two-wheeler registration total in September and October 2026, with the change in percentage points.
Kerala had the largest share loss. Its share of the state-wise total fell from 5.82% to 4.02%, a drop of 1.80 percentage points, and it slipped from seventh to eleventh. Tamil Nadu lost 1.72 points and Karnataka 1.39. Those three declines add up to 4.91 points of share.
Rajasthan and Andhra Pradesh made the largest gains. Rajasthan rose 1.43 points, from 5.71% to 7.14%, and Andhra Pradesh rose 1.20 points, from 3.92% to 5.12%. Odisha, Gujarat and Telangana also gained share, while Maharashtra and Uttar Pradesh held roughly steady.
Rank and change can point in different directions. Odisha finished sixth, one place above Rajasthan, because its October total of 14,882 is larger than Rajasthan’s 14,574. Rajasthan, though, added 2,659 units to Odisha’s 1,546. The rank tells you how big a state’s base is, and the change tells you which way it is moving. A reader needs both.
Units tell the same story from a different angle. The five states that fell lost 12,507 registrations between them. The six that rose added 9,102. The eleven states shown therefore lost a net 3,405 between them, with the smaller states and territories outside the table also slightly lower.
The festival calendar moved this year
Festive timing is the first thing to check, but the calendar shifted between the two years. In 2025, Sharad Navratri began on 22 September and Dussehra fell on 2 October, with Diwali on 20 October. In 2026, Navratri ran from 11 to 19 October, Dussehra fell on 20 October and Diwali falls on 8 November.
That changes how September and October compare. In 2025 the festive run began in late September, so some festive buying could have landed in September. In 2026 nearly all of that run sits in October, which could pull some registrations into October. This is a hypothesis, and the figures do not prove it.
The eleven largest states lost a net 3,405 registrations in October, which is hard to square with a festive lift that helped every state. It may have helped some states more than others. The state-wise data for October 2025 would be needed to test that, and it is not available here.
Onam came earlier. Thiruvonam fell on 26 August 2026, which means Kerala’s September-to-October fall happened well after the festival. Whether festival buying in August showed up in Kerala’s figures cannot be checked from this comparison.
What the state-wise figures cannot tell you
A monthly change in registrations is not a direct measure of demand. Registrations can lag sales: a vehicle sold at the end of September may only be registered in October. Dealer stocking, fleet deliveries and a single large order can also move a state’s figures sharply.
None of those explanations is confirmed for any state in this table. Attributing Rajasthan’s gain to one brand, or Kerala’s fall to one event, would go beyond what these totals show. A broad rise across many districts and brands points to a different cause from a single fleet order, and that is the kind of evidence this comparison cannot provide.
For a buyer, a statewide rise says more about the market than about stock at a particular showroom. Whether a model is available near you depends on local dealers, not on the state total. For a dealer or manufacturer planning stock, the practical question is whether October’s level holds into November, which makes the three-month view more useful than a single month.
State policy is the other obvious check. Subsidies, road-tax rules and registration charges can shift buying within a month, and state EV rules have changed in recent years. We have not verified a state notice that took effect in September or October 2026, so this article does not treat policy as a cause.
The most useful next test is the year-on-year comparison at state level. Until October 2025 figures for each state are checked on the same basis, it is not possible to say whether Rajasthan’s or Kerala’s movement is unusual for the month.
What November should show
November will show whether festive buying in these states lands in October or spills into November, since Diwali falls on 8 November. If Rajasthan and Andhra Pradesh hold their October levels after the festival, the gains look more durable. If Kerala and Tamil Nadu recover, October looks more like a timing effect than a change in trend.
Watch the three-month total as well as the single month. A month can be distorted by when registrations were processed, and a second and third month of similar movement carries more weight than one strong month.
