ICCT Study: India’s Battery Demand Could Reach 573 GWh by 2050
ICCT’s latest study highlights the scale of battery demand India could face as EV adoption accelerates, with annual demand potentially reaching 573 GWh by 2050. Day One of ICTS 2026 also highlighted the growing importance of battery manufacturing, recycling, policy implementation and energy security.
ICCT’s new study projects India’s annual battery demand could reach 573 GWh by 2050. Discussions on Day One of ICTS 2026 showed why manufacturing, recycling, policy and energy security will matter just as much as EV sales.
India's electric vehicle transition is often reduced to a simple question: how quickly are EV sales growing?
But the discussions on Day One of the India Clean Transportation Summit 2026 in New Delhi pointed towards a much bigger question. As EV adoption accelerates, can India build enough of the industrial ecosystem behind those vehicles to keep pace with demand?
That question gains significance with the release of a new ICCT working paper, India’s EV transition: Impact of electric vehicle battery demand on import payments from 2024 to 2050. The study examines how EV adoption could influence battery demand, domestic manufacturing and India's import payments under different electrification and battery localisation scenarios.
Battery Demand Could Become a Major Part of India's EV Story
The numbers give a sense of the scale of what lies ahead. ICCT estimates that annual battery demand will increase sharply after 2030. By 2050, the requirement could reach around 340 GWh under the Baseline scenario and around 573 GWh under the Ambitious scenario.
That is where the EV story becomes an industrial story.
More EVs mean more batteries. More batteries mean greater requirements for cells, manufacturing capacity, raw materials, electricity, logistics and eventually recycling. The size of the future battery market therefore matters not only to automakers and battery companies, but also to India's broader trade and energy strategy.
The ICCT study looks at this through different battery manufacturing pathways, from no localisation to high localisation. The analysis indicates that greater domestic manufacturing can reduce dependence on imported batteries as demand grows.
The important point is that EV adoption and battery localisation are not the same thing. India can increase EV penetration while continuing to depend on imported batteries. The bigger opportunity lies in using the scale of the EV market to build more of that supply chain within the country.
The Import Bill Tells a More Complicated Story
There is another reason the battery demand projection matters.
India's EV transition is expected to reduce its dependence on imported oil, but if battery demand grows faster than domestic manufacturing, some of that new demand could translate into higher battery imports.
ICCT's analysis therefore considers both oil and battery imports. Its conclusion is that electrification remains the dominant factor affecting India's import bill, with higher battery localisation offering additional import savings.
This creates an interesting middle ground in the transition.
India does not necessarily need to wait until every part of the battery supply chain is domestic before EVs start delivering energy security benefits. Replacing petroleum consumption with electricity can already reduce oil import requirements.
However, deeper localisation could allow the country to capture more of the economic value created by that transition.
In simple terms, India could reduce what it imports by electrifying transport, and reduce it further by manufacturing more of what those electric vehicles need.
What Stood Out on Day One
The ICCT report was one part of a much wider conversation on the first day of the summit.
Across the sessions, the discussion repeatedly moved beyond the vehicle itself and towards the systems needed to make clean transportation work at scale. Panels and research discussions covered areas including battery manufacturing, recycling, infrastructure and the practical challenges of implementing EV policies across different states.
One of the key discussions focused on gigafactories and battery recycling. Experts highlighted the need to expand domestic battery manufacturing while building a larger recycling ecosystem, both of which could help reduce dependence on imported cells and support the economics of EVs.
That conversation is important because recycling is usually treated primarily as an end-of-life issue. It may eventually become something much bigger.
Recycling Could Become Part of India's Battery Supply Chain
As the number of EVs on Indian roads increases, the country will eventually have a growing pool of batteries reaching the end of their first vehicle life.
A mature recycling industry could recover useful materials from these batteries and put them back into the wider supply chain. It would not eliminate the need for imported raw materials, but it could become another source of materials as India's battery industry grows.
This changes the way recycling should be viewed.
It is not only about dealing with batteries after they are discarded. It can also become part of the infrastructure supporting India's future battery manufacturing capacity.
That makes the simultaneous development of gigafactories and recycling capacity particularly relevant.
The EV Transition Will Also Be a State-Level Execution Challenge
Another point that emerged from the Day One discussions was less visible but equally important: the experience of building and operating an EV business can vary significantly from one state to another.
Electricity tariffs, incentives, infrastructure approvals, land-related processes and other administrative requirements can influence the speed and economics of EV deployment and manufacturing.
For companies making large investments in battery plants or charging infrastructure, predictability can matter almost as much as the incentive itself.
India may have a national EV transition, but much of its execution happens at the state level.
That means the next stage of EV growth will depend not just on how ambitious national policies are, but also on how consistently they can be implemented on the ground.
The Consumer Will Eventually Feel the Impact
There is a direct connection between all of this and the person buying an EV.
Today's EV conversation is heavily focused on range, charging time, performance and features. But as the technology becomes more mainstream, affordability will become increasingly important.
Battery costs remain a critical part of the economics of an electric vehicle. Greater manufacturing scale, domestic production and recycling could eventually help improve the cost structure of the industry.
Localisation, therefore, is not simply about reducing India's import dependence.
For consumers, its eventual impact could be much simpler: how much an EV costs to buy and own.
Electrification and Localisation Need to Move Together
The ICCT study ultimately presents a useful way of separating two ideas that are often discussed together.
Electrification can reduce India's dependence on imported oil even when some batteries continue to come from overseas. At the same time, increasing battery localisation can generate additional import savings.
That suggests India does not face an either-or choice.
The country can continue pushing EV adoption while simultaneously building domestic battery capacity. The two can reinforce each other.
The immediate objective is to get more vehicles running on electricity. The longer-term objective is to ensure that more of the value created by that transition stays within the country.
What Day One Says About India's Next EV Chapter
Perhaps the biggest takeaway from Day One of ICTS 2026 was the way different pieces of the EV transition began to connect.
The battery demand projected by ICCT connects directly with the need for manufacturing capacity. Manufacturing connects with raw materials and electricity. Recycling connects back to the battery supply chain. State-level policies influence how quickly companies can build and deploy. And the resulting shift away from oil has implications for India's import bill and energy security.
The numbers put the scale into perspective. Annual battery demand could reach around 340 GWh under the Baseline scenario and 573 GWh under the Ambitious scenario by 2050.
That is a very different challenge from simply selling more electric vehicles.
| What India needs to scale | Why it matters |
| EV adoption | Reduces dependence on petroleum |
| Battery manufacturing | Reduces dependence on imported cells |
| Raw material supply chains | Supports long-term battery production |
| Battery recycling | Creates a secondary source of materials |
| Charging infrastructure | Makes large-scale EV adoption practical |
| Consistent state policies | Helps businesses scale faster |
| Domestic manufacturing | Keeps more economic value within India |
The EV transition, therefore, is entering a stage where the vehicle itself may no longer be the most interesting part of the story.
The bigger story is everything being built around it.
India's success in electric mobility will ultimately be measured not only by how many EVs are on its roads, but by how much of the ecosystem powering those EVs the country can build, scale and sustain itself.
