MG Unveils ADAPT: A New Platform for Its Future EVs and Hybrids
MG Motor India has unveiled ADAPT, a new flexible platform under its Drive.NEV architecture that will underpin the brand's future EVs, PHEVs, strong hybrids, and range-extender hybrids, with no plans for a petrol-only model.
MG Motor India has officially revealed its new technology platform, ADAPT, as part of its broader Drive.NEV electrified vehicle architecture. In simple terms, ADAPT is the foundation MG will use to build its future electric, hybrid, and plug-in hybrid vehicles.
What is a "platform," in simple terms?
A platform is essentially the skeleton of a car, the base structure holding the battery, motor, wheels, and other core components. Rather than engineering a new base for every model, car companies build one flexible platform and create multiple cars on top of it. This saves development time and cost, and helps a brand launch new models faster.
MG says ADAPT is built to support:
- Fully electric vehicles (EVs)
- Plug-in hybrids (PHEVs)
- Strong hybrids
- Range-extender hybrids
Notably absent from that list is a plain petrol-only model, a clear sign of where MG's future line-up is headed.
The petrol engine that plays a supporting role
Even hybrid and plug-in hybrid cars need a petrol engine, and MG has built one specifically for ADAPT. The company claims a thermal efficiency of up to 43 percent.
In simple terms, thermal efficiency measures how much of the fuel's energy is actually converted into useful motion, rather than wasted as heat. Most conventional petrol engines sit between 20 and 35 percent, so a claimed 43 percent is a strong figure, if it holds up in real-world conditions.
MG hasn't released the engine's displacement, cylinder count, or power output yet.
This general approach, a highly efficient petrol engine acting mainly as a support/generator rather than the primary driver, is similar in spirit to what China's BYD has done with its DM-i (Dual Mode-intelligent) hybrid technology, one of the best-known plug-in hybrid systems globally. BYD's DM-i system also prioritises electric-first driving, with the engine stepping in mainly to generate power or assist at higher speeds. It's a useful reference point for understanding the direction MG's ADAPT engine appears to be taking, though the two are separate, independently developed systems.
A gearbox built for smoother power delivery
MG's new engine pairs with a DHT, dedicated hybrid transmission. Most hybrids today use a simpler e-CVT setup; a DHT uses proper mechanical gears, which typically delivers a more natural, traditional driving feel.
The DHT includes an electromagnetic clutch that MG claims reacts four times faster than a conventional clutch. There's also a “10-in-1 drive unit”, a compact assembly combining an electric motor with a two-speed gearbox, that manages how power from the engine and motor reaches the wheels.
Four driving modes
MG detailed four operating modes for the system:
- Parallel mode - engine and electric motor drive the wheels together
- Series mode - the engine acts purely as a generator, charging the battery, while the motor alone drives the wheels
- Engine Direct mode - only the petrol engine powers the wheels
- Pure EV mode - the engine switches off completely; the car runs purely on battery and motor
Different vehicle types on ADAPT will likely use different combinations of these modes, a full EV, for instance, would only ever run in Pure EV mode.
What this means for buyers
A shared, flexible platform like ADAPT typically translates into faster new-model launches and better cost efficiency for the manufacturer, some of which can filter down to buyers through pricing and features. It also signals that MG India's product pipeline going forward will lean heavily on electrified powertrains rather than conventional petrol engines alone.
MG’s October 2026 Retail Sales: Tomahawk Falls Short of Expectations
Mahindra EV Registrations Rise 86.5% YoY in October 2026; XEV 9S Leads, BE6 Rebounds
