MG Hector Tomahawk EV Launched With 517 Km Range, 69.2 kWh Battery and Level 2 ADAS
MG has launched the Hector Tomahawk EV in five-seat and seven-seat configurations, with prices starting at ₹19.49 lakh. It gets a 69.2 kWh battery, 150 kW motor, 517 km claimed MIDC range and up to 90 kW DC fast charging.
MG Motor India has launched the Hector Tomahawk EV, its new electric SUV offered in both five seat and seven seat configurations. The model combines a 69.2 kWh battery with a Permanent Magnet Synchronous Motor, delivering 150 kW of maximum power and 310 Nm of peak torque.
The Hector Tomahawk EV claims a range of 517 km on a single charge under the MIDC test cycle and is available in three variants: Excite, Exclusive and Essence. The seven seat version is offered across all three variants, while the five seat configuration is available in the Essence trim.
MG Hector Tomahawk EV price and variants
The Hector Tomahawk EV is priced from ₹19.49 lakh and goes up to ₹23.49 lakh, ex-showroom.
| Variant | 5 Seater | 7 Seater |
| Excite | Not available | ₹19.49 lakh |
| Exclusive | Not available | ₹21.99 lakh |
| Essence | ₹22.99 lakh | ₹23.49 lakh |
MG is also offering the Hector Tomahawk EV under a Battery-as-a-Service (BaaS) ownership programme. Under this arrangement, the vehicle and battery are financed separately through two loans. The seven-seat Excite is priced at ₹13.99 lakh, the seven-seat Exclusive at ₹15.99 lakh and the seven-seat Essence at ₹17.49 lakh, while the five-seat Essence is priced at ₹16.99 lakh.
The BaaS structure carries a battery finance component equivalent to ₹4.90 per km, based on the assumed monthly running used for the calculation. This should not be treated as a per-kilometre running charge, as the battery component is repaid through a separate loan and the customer remains liable for the applicable EMI irrespective of actual monthly usage.
The exact loan amount, down payment, interest rate, tenure, taxes and other applicable charges will depend on the financing arrangement and lender terms.
69.2 kWh battery delivers 517 km claimed range
Powering the Hector Tomahawk EV is a 69.2 kWh high voltage battery pack paired with a Permanent Magnet Synchronous Motor.
The electric motor produces 150 kW of maximum power and 310 Nm of maximum torque. The SUV uses an automatic transmission and gets a CCS2 charging connector. Its claimed range stands at 517 km on a single charge under the MIDC test cycle.
MG Hector Tomahawk EV powertrain specifications
| Specification | Details |
| Battery capacity | 69.2 kWh |
| Motor | Permanent Magnet Synchronous Motor |
| Maximum power | 150 kW |
| Maximum torque | 310 Nm |
| Claimed range | 517 km, MIDC |
| Charging connector | CCS2 |
| Maximum DC charging | 90 kW |
| Transmission | Automatic |
The Hector Tomahawk EV supports DC fast charging at up to 90 kW. A 30% to 80% charge is estimated to take around 35 minutes using a 90 kW DC charger.
With a 7.4 kW AC charger, the estimated charging time from 10% to 100% is around 12.5 hours. The SUV also comes with a 3.3 kW portable charging cable.
Charging times can vary depending on factors such as battery condition, temperature and the charging infrastructure being used.
Five and seven seat configurations
The Hector Tomahawk EV measures 4,745 mm in length, 2,130 mm in width including mirrors and 1,770 mm in height, with a 2,810 mm wheelbase.
The five seat version offers 610 litres of boot space, which increases to 1,053 litres with the second row folded. The seven seat version offers 192 litres with all three rows in use and 528 litres with the third row folded.
The SUV has 230 mm of ground clearance.
| Dimension | Details |
| Length | 4,745 mm |
| Width with mirrors | 2,130 mm |
| Width without mirrors | 1,850 mm |
| Height | 1,770 mm |
| Wheelbase | 2,810 mm |
| 5 seat boot space | 610 litres |
| 5 seat boot with second row folded | 1,053 litres |
| 7 seat boot space | 192 litres |
| 7 seat boot with third row folded | 528 litres |
| Ground clearance | 230 mm |
Level 2 ADAS available on the Essence variant
The top Essence variant gets an Autonomous Level 2 ADAS package. The system includes functions such as Adaptive Cruise Control, Bend Cruise Assistance, Traffic Jam Assist, Lane Keep Assist, Lane Departure Warning, Lane Departure Prevention, Forward Collision Warning and Automatic Emergency Braking.
It also includes Automatic Emergency Braking for pedestrians, Intelligent Hydraulic Braking Assistance and Intelligent Headlamp Control.
The Excite and Exclusive variants do not get the listed Level 2 ADAS functions.
Six airbags and 360 degree camera
Safety equipment on the Hector Tomahawk EV includes six airbags, Electronic Stability Program, Traction Control System, Hill Hold Control, ABS with EBD, Brake Assist and four wheel disc brakes.
The SUV also gets an electric parking brake with Auto Hold, direct tyre pressure monitoring, ISOFIX child seat anchors, rear parking sensors and a reverse parking camera.
Higher variants get a 360 degree HD camera system with transparent chassis and wheel view, while front parking sensors are available on the Essence variant.
15.6 inch touchscreen on the top variant
Inside, the Hector Tomahawk EV gets a 22.3 cm, or 8.8 inch, multi information display.
The Excite and Exclusive variants feature a 32.5 cm, or 12.8 inch touchscreen, while the Essence gets a larger 39.6 cm, or 15.6 inch Grand View touchscreen.
The top variant also gets a Premium Sound System by Infinity with 10 speakers, including a subwoofer. Wireless Android Auto and Apple CarPlay are offered across the variants.
Connected technology remains a major focus
The Hector Tomahawk EV gets MG's i-SMART connected car technology, with features including vehicle status checks, Find My Car, geofencing, charging station search, charging notifications, over the air updates, remote AC controls and live location sharing.
It also features a Gen AI powered advanced voice assistant, conversational chat capability and more than 30 Hinglish voice commands. Voice commands are available in six languages: Tamil, Telugu, Marathi, Gujarati, English and Hindi.
Other connected functions include scheduled charging through the infotainment system and i-SMART app, digital Bluetooth key sharing, remote locking and unlocking, and Siri shortcuts.
V2L, V2V and V2H functionality
The Hector Tomahawk EV also supports Vehicle-to-Load (V2L), Vehicle-to-Vehicle (V2V) and Vehicle-to-Home (V2H) functionality.
These systems allow the vehicle to be used as an energy source beyond simply powering itself, with V2L supporting external electrical loads and V2V enabling energy transfer to another compatible electric vehicle. V2H is intended to enable power transfer between the vehicle and a compatible home setup.
Ventilated seats, panoramic-style cockpit sunroof and more
The Hector Tomahawk EV also offers a wide range of comfort features depending on the variant. These include a dual pane cockpit sunroof, front ventilated seats, automatic powered tailgate, multiple drive modes, power adjustable seats, rain sensing wipers, automatic headlamps and PM2.5 filtration.
The Exclusive and Essence variants also get a 50W fast wireless charger with cooling. The seven seat versions add features such as second row sliding, third row AC vents and easy second row tip and tumble access to the third row.
MG Hector Tomahawk EV: key specifications
| Seating | 5 and 7 seats |
| Battery | 69.2 kWh |
| Power | 150 kW |
| Torque | 310 Nm |
| 30% to 80% DC charging | Approx. 35 minutes |
| 10% to 100% AC charging | Approx. 12.5 hours at 7.4 kW |
| Length | 4,745 mm |
| 7 seat boot space | 192 litres with all rows up |
| ADAS | Level 2, Essence variant |
MG Hector Tomahawk EV brings a broad equipment mix
With a 69.2 kWh battery, 517 km claimed MIDC range, 150 kW motor and five or seven seat layouts, the Hector Tomahawk EV combines the practicality of a large family SUV with an electric powertrain.
The model's equipment list extends from Level 2 ADAS and a 15.6 inch touchscreen on the top variant to connected-car technology, multiple charging options and V2X capabilities. MG is also offering a BaaS ownership option, allowing buyers to finance the vehicle and battery separately through a dual-loan structure.
For buyers looking at a three-row electric SUV, the Hector Tomahawk EV's combination of seating flexibility, claimed range, charging capability and technology makes its positioning particularly relevant to the growing family EV segment.
Renault Duster Hybrid vs Maruti Suzuki Grand Vitara Hybrid: Base, Mid, and Top Variant Comparison
Exclusive: MG Hector Tomahawk EV Charges Faster than MG Advertises
