Kia Syros EV vs MG Windsor EV: Range, Features, Charging and Specs Compared
The Kia Syros EV and MG Windsor EV offer contrasting strengths in India's growing EV market. Here's how they compare on dimensions, range, charging, features, safety and practicality to help buyers choose the right electric car.
Kia Syros EV and MG Windsor EV appear to target the same audience. Look closer, however, and they represent two distinct approaches to electric mobility. Kia has built the Syros EV as a compact electric SUV that prioritises performance, charging capability and connected technology, while MG has focused on passenger comfort, cabin space and ownership flexibility through initiatives such as Battery-as-a-Service (BaaS).
That means the decision isn't simply about choosing the EV with the bigger battery or longer claimed range. Factors such as charging speed, rear-seat comfort and everyday usability are just as important. Here's how the two compare.
Dimensions & Practicality
| Specification | Kia Syros EV | MG Windsor EV |
| Length | 3,995 mm | 4,295 mm |
| Width | 1,805 mm | 1,850 mm |
| Height | 1,670 mm | 1,677 mm |
| Wheelbase | 2,550 mm | 2,700 mm |
| Ground Clearance | Not Disclosed | 186 mm |
| Boot Space | Not Disclosed | 604L (38 kWh), 579L (52.9 kWh) |
| Frunk | 16L | Not Mentioned |
The difference isn't just in size, it influences how each vehicle fits into everyday life.
With a 150 mm longer wheelbase, the Windsor EV is expected to offer more generous rear-seat legroom, while its larger boot makes it a stronger choice for family trips and airport runs. Buyers who regularly travel with passengers are likely to appreciate the additional space.
The Syros EV takes the opposite approach. Its sub-four-metre dimensions should make it easier to navigate congested city roads and tighter parking spaces. A 16-litre frunk also provides a convenient place to store charging cables or smaller belongings, while sliding rear seats (variant dependent) offer greater flexibility between passenger and luggage space.
Battery, Performance & Range
| Battery | 42 kWh / 51.4 kWh | 38 kWh / 52.9 kWh |
| Motor | Permanent Magnet Synchronous Motor | Permanent Magnet Synchronous Motor |
| Power | 135 PS / 171 PS | 136 PS |
| Torque | 255 Nm | 200 Nm |
| Drive | Front-Wheel Drive | Front-Wheel Drive |
| Claimed Range | 443 km / 526 km (MIDC) | 332 km / 449 km (MIDC) |
Both EVs use front-mounted permanent magnet synchronous motors, but Kia has adopted a broader performance strategy.
The entry-level Syros EV closely matches the Windsor EV's output, while the larger battery variant develops 171 PS and 255 Nm. The additional power is likely to be most noticeable during highway overtakes, steep inclines and when travelling with a full load of passengers and luggage.
The two EVs also use different battery chemistries. The MG Windsor EV is equipped with a Lithium Iron Phosphate (LFP) battery, known for its thermal stability, durability and long cycle life. The Kia Syros EV, meanwhile, uses Nickel Manganese Cobalt (NMC) cells, which generally offer higher energy density, helping deliver more power and longer driving range for a given battery size.
Range is another area where Kia leads The Syros EV delivers a claimed 443 km and 526 km (MIDC) depending on the battery pack, compared with 332 km and 449 km (MIDC) for the Windsor EV.
Buyers should note that these are MIDC-certified laboratory figures, and real-world driving range will vary depending on traffic, terrain, driving style and weather conditions.
Kia also equips the Syros EV with Battery Conditioning, which prepares the battery before reaching a DC fast charger to help achieve optimal charging performance under suitable conditions.
| DC Charging | Up to 100 kW | Up to 45 kW / 60 kW |
| Fast Charging | 10-80% in 39 mins | 20-80% in 45–50 mins |
| AC Charging | 7.4 kW / 11 kW | Portable Charger + Optional 7.4 kW Wall Box |
As India's DC charging network continues to expand, charging speed is beginning to influence buying decisions just as much as battery capacity.
The Syros EV supports up to 100 kW DC fast charging, allowing a claimed 10-80 per cent recharge in 39 minutes. Shorter charging sessions can make a noticeable difference on long-distance journeys where multiple charging stops are required.
The Windsor EV's charging speeds are lower, but they remain well suited to routine commuting and overnight home charging.
Kia further enhances the ownership experience with EV-specific features such as Battery Conditioning, i-Pedal single-pedal driving, Vehicle-to-Load (V2L) capability and OTA software updates.
Features & Interior
| Feature | Kia Syros EV | MG Windsor EV |
| Display | 30-inch Trinity Display | 15.6-inch Touchscreen |
| Audio | Harman Kardon 8-speaker | Infinity 9-speaker |
| Panoramic Roof | Dual-pane | Infinity View Glass Roof |
| Rear Seats | Sliding & Reclining | 135° Aero Lounge Reclining |
| Rear Seat Ventilation | Yes | No |
| Connected Features | 95+ Kia Connect | i-SMART |
| Digital Key | Yes | Yes |
| OTA Updates | Yes | Not Specified |
| V2L | Yes | Yes |
| V2V | Not Mentioned | Yes |
The Syros EV is clearly aimed at drivers who value a connected, digital-first experience. Its expansive Trinity Display, Digital Key, OTA updates and extensive Kia Connect ecosystem create a cockpit that feels modern and technology-focused.
The Windsor EV shifts the emphasis towards passenger comfort. Reclining Aero Lounge rear seats, a premium Infinity audio system and a more spacious cabin make it particularly attractive for buyers who regularly travel with family or spend long hours on the road.
Safety & ADAS
| Airbags | 6 | 6 |
| ESC | Yes | Yes |
| 360° Camera | Yes | Yes |
| Parking Sensors | Front & Rear | Front & Rear |
| Level 2 ADAS | Yes (X-Line) | Yes |
Neither EV asks buyers to compromise on safety. Both offer six airbags, electronic stability control, a 360-degree camera, parking assistance and Level 2 ADAS.
Kia highlights 16 autonomous driving assistance functions on the X-Line variant, while MG offers a comparable suite of technologies including adaptive cruise control and lane-keeping assistance.
Verdict: Which EV Should You Buy?
The Kia Syros EV and MG Windsor EV demonstrate how rapidly India's EV market has evolved. Rather than competing on specifications alone, they cater to different ownership priorities.
The Kia Syros EV is likely to appeal more to buyers seeking a compact electric SUV with stronger performance, longer certified range, quicker charging and a connected, driver-focused cabin.
The MG Windsor EV, meanwhile, is better suited to those who value passenger comfort, cabin space and ownership flexibility. Features such as the larger boot, Aero Lounge rear seats, Battery-as-a-Service and V2V charging strengthen its appeal as a family-oriented electric vehicle.
Neither is objectively the better choice. Instead, the right decision depends on how and where you'll use your EV. If your priority is driving range, charging convenience and in-car technology, the Syros EV makes a compelling case. If comfort, practicality and everyday family usability matter more, the Windsor EV deserves equal consideration.
Renault Duster Hybrid vs Maruti Suzuki Grand Vitara Hybrid: Base, Mid, and Top Variant Comparison
Exclusive: MG Hector Tomahawk EV Charges Faster than MG Advertises
