Tata Nexon.ev vs Kia Syros EV: A Variant-by-Variant Comparison
Tata Nexon.ev vs Kia Syros EV, compared trim by trim, from the entry-level HTK 42 up to the range-topping X-Line ER with ADAS. A clear look at where each EV pulls ahead on range, power, and features.
The compact electric SUV space in India is about to get a lot more interesting. Tata's Nexon.ev has been the segment's benchmark for a while now, but Kia's upcoming Syros EV is shaping up to be a serious challenger. With the Syros EV's prices still officially "TBD," we don't have the full picture yet, but the specifications and features that have already been revealed give us enough to run a proper comparison.
On the Kia side, it's worth understanding the variant hierarchy first: the X-Line ER sits at the very top of the Syros EV range and is the only variant with Level 2 ADAS. The HTX and HTX+ ER, despite being well-equipped, sit just below it, essentially top-spec trims minus the ADAS suite. Keeping that in mind makes this comparison easier to follow.
Here's how the two stack up, variant for variant.
Entry Level: Nexon.ev Creative 45 vs Syros EV HTK 42
At the base of the range, the Nexon.ev Creative 45 comes in at ₹14,14,000 (ex-showroom) and has the edge on raw numbers, a bigger 45 kWh battery, more motor power (106 kW vs 99 kW), and a longer ARAI-claimed range of 489 km against the Syros EV's 443 km.
But numbers on a spec sheet only tell half the story. The Syros EV HTK 42, even at this entry point, counters with more torque (255 Nm vs 215 Nm), a frunk, a bigger boot, faster DC charging, and support for 11 kW AC charging compared to the Nexon.ev's 7.2 kW. It also brings a noticeably larger 12.3-inch infotainment setup against the Nexon.ev's 7-inch unit, wireless Android Auto and Apple CarPlay, and a long list of comfort features, rear AC vents, auto headlamps, LED fog lamps, rear window sunshade, electrically foldable mirrors, and an air purifier, none of which the base Nexon.ev variant offers.
In short, the Nexon.ev wins on the range-and-power spec sheet at this level, but the Syros EV looks like it's trying to pack in a lot more equipment for buyers who care about day-to-day convenience.
Nexon.ev Empowered 45 vs Syros EV HTX and HTX+ ER (Top-Spec, Minus ADAS)
Tata's Empowered 45, priced at ₹16,14,000, is pitched here against two Syros EV trims, the HTX and the higher HTX+ ER. Both of these Kia trims sit just below the X-Line ER in the lineup, carrying most of the top-spec equipment but without the ADAS suite.
The Nexon.ev Empowered 45 still runs the 45 kWh/106 kW setup, with 489 km of range, and holds its own with a full 360-degree camera, a blind spot monitor, and an air purifier, features missing on both Syros EV trims here. It also gets in-cluster navigation, which the HTX misses out on, though the HTX+ ER does match it. The Nexon.ev does have a single-pane sunroof rather than a panoramic one, though.
The Syros EV HTX sticks with the smaller 42 kWh battery and 99 kW motor, but adds a panoramic sunroof, single-pedal drive, rear seat slide-and-recline, all-window one-touch operation, and a rear window sunshade.
The HTX+ ER goes further still: the bigger 51.4 kWh battery, 126 kW motor, 255 Nm torque, 526 km range, 17-inch alloys, panoramic sunroof, driver and co-driver ventilated seats, rear ventilated seats, driver power-adjustable seat, smart dashcam, battery heating system, and a 12.3-inch navigation cockpit with Harman Kardon sound. It's clearly aimed at buyers who want most of the flagship experience, though, like the HTX, it comes without ADAS, an air purifier, or a blind spot monitor, the last two of which the Nexon.ev Empowered 45 has.
Nexon.ev Empowered+ A 45 vs Syros EV X-Line ER (Kia's Top Variant)
Finally, this is where the Syros EV shows its full hand. The X-Line ER is Kia's range-topping variant, and it's priced against the Nexon.ev Empowered+ A 45 (₹17,49,000), which still runs the same 45 kWh battery and 106 kW motor as the base trim. The X-Line ER, by contrast, gets the larger 51.4 kWh battery with 126 kW of motor power, 255 Nm of torque, and a claimed ARAI range of 526 km, comfortably ahead of the Nexon.ev's 489 km.
Being the top variant, the X-Line ER is also the only Syros EV trim with Level 2 ADAS (16 features), well ahead of the Nexon.ev's L1 ADAS system (9 features). It further brings single-pedal drive, driver power-adjustable seat, rear ventilated seats, rear seats with slide-and-recline function, one-touch up-down for all windows, a smart dashcam, battery heating, and a digital key.
The Nexon.ev does hold on to a few practical advantages even here: it comes with a 7.2 kW charger included in the box, rain-sensing wipers, and a built-in air purifier, none of which the X-Line ER offers. Both use a 12.3-inch infotainment screen, though the Nexon.ev pairs a JBL 9-speaker system with a 10-inch instrument cluster, while the Syros EV goes with an 8-speaker Harman Kardon setup and a 12.3-inch instrument cluster.
The Takeaway
A clear pattern emerges across these comparisons. At the entry level, the Nexon.ev leads on range and motor output, while the Syros EV counters with a longer feature list. As you move up, the Syros EV's HTX and HTX+ ER trims add most of the flagship equipment but skip ADAS, that's reserved exclusively for the X-Line ER, Kia's true range-topping variant, which also gets the bigger battery, more power, and the longest range in the lineup. The Nexon.ev, meanwhile, holds on to a few features across the board that Kia leaves out even at the top, like the air purifier and the 360-camera/blind spot monitor combo.
With Syros EV pricing still unannounced, the final verdict will come down to how aggressively Kia prices it against the Nexon.ev. If it lands close to Tata's numbers, the extra features could make it a strong case. If it comes in noticeably higher, the Nexon.ev's simpler, no-frills value proposition may still hold up. Either way, buyers in this segment are about to have a genuinely tough choice on their hands, and that's good news for anyone shopping for a compact electric SUV in India right now.
