1,459 km in a Nexon EV 45: Real-World Highway Range & Charging Report
Harsha drove 1,459 km from Hyderabad to Shirdi and back in a Nexon EV 45. Four adults, 60 kg luggage, 42°C heat. Here is the complete real-world data — range per leg, charging costs, infrastructure reliability and what it actually cost vs petrol.
Can you drive from Hyderabad to Shirdi and back in a Nexon EV 45 — with four adults, a full boot, and 42°C summer heat — without drama?
Harsha did. And he documented every kilometre.
This article is based on a trip log submitted by Harsha to ElecTree's EV Road Trip platform. View the complete pit stop by pit stop breakdown here.
Quick Verdict
| Metric | Value |
| Total Distance | 1,459 km |
| Total Driving Time | 26 hours 53 minutes |
| Charging Stops | 6 |
| Total Charging Time | 5 hours 7 minutes |
| Total Charging Cost | ₹4,660 |
| Overall Efficiency | 6.67 km/kWh (150 Wh/km) |
| Petrol Equivalent Cost* | ~₹10,213 |
| Saving vs Petrol | ~₹5,553 |
| Verdict | Doable. Plan charging stops at 20% SoC minimum. |
*Petrol at ₹105/litre, 15 km/l highway efficiency for a comparable ICE SUV.
The Vehicle and Conditions
- Car: Tata Nexon EV Empowered Plus 45 (45 kWh battery)
- Odometer at start: 25,530 km
- Passengers: 4 adults
- Boot load: 60 kg
- Departure: 4:00 AM, April 18, 2026
- Ambient temperature: 38–42°C throughout
- AC: Running at 23–25°C for the entire trip
- Regen braking: Level 2–3 across most legs
The ARAI-claimed range of the Nexon EV 45 is 489 km. In these conditions — maximum passenger load, peak summer heat, AC on full — the effective range per charge cycle was approximately 300 km. That is 61% of the ARAI figure. This is not a criticism of the car. It is what any vehicle delivers when carrying four adults through a 42°C Indian summer. Knowing this number before you plan is the point of this article.
The Route
- Hyderabad → Omerga → Beed → Shirdi (Day 1)
- Shirdi → Aurangabad → Beed → Omerga → Hyderabad (Day 2)
Pit Stop Ledger
| Leg | Distance | Arrival SoC | Avg Speed | Charger | Charging Time | Cost |
| Hyderabad → Omerga | 202 km | 28% | 53 kmph | Chargezone 60 kW | 32 min (28%→78%) | ₹480 |
| Omerga → Beed | 212 km | 6% | 44 kmph | Nikol EV 60 kW | 60 min (6%→95%) | ₹980 |
| Beed → Shirdi | 256 km | 7% | 45 kmph | Jio BP Pulse 60 kW | 90 min (7%→100%) | ₹1,000 |
| Shirdi → Aurangabad | 211 km | 38% | 79 kmph | EV Pump 60 kW | 45 min (38%→95%) | ₹600 |
| Aurangabad → Beed | 131 km | 40% | 43 kmph | Nikol EV 60 kW | 35 min (40%→95%) | ₹600 |
| Beed → Omerga | 213 km | 15% | 75 kmph | Chargezone 120 kW | 45 min (15%→94%) | ₹1,000 |
| Omerga → Hyderabad | 234 km | — | 56 kmph | — | — | — |
| Total | 1,459 km | 23% final | 5h 7m | ₹4,660 |
The instrument cluster at the end of the journey independently verified the data.
Charging Cost vs Petrol
| Metric | Nexon EV 45 (Actual) | Petrol SUV (Estimated) |
| Total fuel/energy cost | ₹4,660 | ~₹10,213 |
| Cost per kilometre | ₹3.19/km | ~₹7.00/km |
| Total saving | ₹5,553 | — |
Petrol estimated at ₹105/litre at 15 km/l highway efficiency. Actual savings will vary by vehicle and fuel price.
On a single trip, the Nexon EV 45 cost less than half what a comparable petrol SUV would have. For a family making this journey once or twice a year, the running cost advantage compounds meaningfully over time.
Infrastructure Reliability Report
This is the section that matters most for anyone planning this route.
- Chargezone (Omerga) — Reliable. Used twice, both times without issue. 60 kW and 120 kW guns available. Good location at a hotel with food available. Recommended as a primary stop on this corridor.
- Nikol EV (Beed) — Reliable and recommended. Used twice. Consistent 60 kW output. Solar-powered setup. Owner is installing a 180 kW charger nearby. This charger saved the trip on Day 1 and is worth bookmarking for anyone on this corridor.
- Jio BP Pulse (Shirdi) — Reliable. Located at the overnight hotel. 80 kW charger delivering 60 kW. Convenient for overnight charging. The hotel also provides EV cars to ferry guests to the temple — useful for Shirdi-bound EV travellers.
- EV Pump (Aurangabad) — Reliable but requires its own app. Worked seamlessly once set up. Download the app before the trip.
- Tata Power (Beed) — Not available. The planned charger was missing entirely.
- BPCL (Beed area) — Not working. Three chargers, all non-functional on the day of visit.
⚠️ The 20% Rule
Harsha's biggest takeaway from the Beed experience: never arrive at a primary charger with less than 20% SoC in remote corridors. The Beed area has over 15 DC chargers within 30 km — infrastructure density is not the problem. Operational reliability on any given day is. A 20% buffer is not overcaution. It is the difference between a detour and a rescue.
What the Data Tells You
Three findings from this trip that apply to any EV owner planning a similar drive:
- Real-world range in Indian summer is approximately 60% of ARAI. With four adults, 60 kg luggage and AC running at 42°C, the Nexon EV 45 delivered around 300 km per charge cycle. Plan legs of 250 km maximum between stops in peak summer.
- The 45 kWh battery is capable on long drives. The car completed a 1,459 km round trip in 45 hours without any battery, thermal or mechanical issues. Harsha's conclusion: he is now confident to plan something longer.
- Always have a backup charger identified. The trip nearly went wrong not because chargers were absent but because the planned ones were unavailable. Identify a backup within 20–30 km of every primary stop before you leave.
The Final Number
₹4,660 for 1,459 km with four adults.
Harsha left at 4:00 AM on April 18. He was home by 1:00 AM on April 20. Two Darshans at Shirdi, one near-miss at a charging stop, and a car that proved it could handle a proper Indian road trip.
The Nexon EV 45 passed this test. The planning almost did not.
Data source: Trip log submitted to ElecTree's EV Road Trip platform by Harsha. View the complete log here.
Image Note: While this article is based on the real-world trip data and odometer logs provided by Harsha, the feature image used is a different Tata Nexon EV 45 to represent highway charging conditions.
MG’s October 2026 Retail Sales: Tomahawk Falls Short of Expectations
Mahindra EV Registrations Rise 86.5% YoY in October 2026; XEV 9S Leads, BE6 Rebounds
